key gets stuck in ignition
Old 10/5/13, 01:18 PM
jkstrader3's Avatar
It seems my 2005 Mustang does not want to go in "Park." I can't get the key out. I have to re-start over and over and finally, I can get the key out. What the heck is going on? Link slipped? Help.
Old 10/6/13, 08:25 AM
2005GeeTee's Avatar
Hmmmm....?
Old 10/9/13, 05:08 AM
daisyjohn's Avatar
The key can only be removed in Park .The switch that sends the signal to the ignition to release the key can be shot. Try using one hand to jiggle the shifter in park, and the other hand to wiggle the key or the lock itself in the ignition is gone or broken. The lock is what the key goes into and also locks the steering wheel. There is also a cable that runs from the shifter to the ignition, which can be getting snagged/broke, stretched to the point it is not working.
Old 10/9/13, 06:33 AM
do you have 4 tons of keys on your key chain? Did you get the key out yet?
tang65c
10/6/15 07:39 PM
DrVet
9/23/15 01:48 PM
BigHoss
9/21/15 10:03 AM
9/8/15 10:45 AM
OneCoolGT
Off-Topic Chatter
9/3/15 07:50 AM
Quick Reply: key gets stuck in ignition
