V6 Performance Mods 2005+ Mustang V6 Performance and Technical Information
turbo or supercharger?
Old 1/12/13, 01:07 PM
  #61
EuroGirl's Avatar
Originally Posted by Nice Pony
The 4.0SOHC has a cast nodular iron crankshaft, not forged steel, but I have never heard of one failing at any horsepower.
The 4.0SOHC rods are forged steel but they are not all that strong and have been known to fail at 450+ RWHP.
The 4.0SOHC pistons are cast hypereutectic aluminum which are very strong but also very brittle. They have a thin top ring land so will not hold up well to detonation. As long as you have a tune that is safe from detonation and all the other components like the fuel pump and injectors are in good shape they can handle a lot of power.
The 4.0SOHC block is cast iron and seems to be very strong but detonation can crack the cylinder wall.
Bottom line is detonation is really bad on the 4.0SOHC so keep your tune safe. Don't push it to the absolute edge and run it a little rich rather than lean. Around 11.5-11.7 WOT AFR seems to be the sweet spot.
Yeah but when you take into account that the GT engine of those years are stronger than the 4.0l and are only safe at about 400rwhp and 450rwhp is pushing it. Having 400rwhp in a 4.0l is pushing the engine and it will fail just a question of when.
Old 1/12/13, 05:04 PM
  #62
legacy Tms Member
JimC's Avatar
EuroGirl - I see you have lots of opinion, but those of us who "have done it" seem to go against your opinion on the strength of the 4.0. What do you drive and what work have you done on a 4.0?
The failures have not been due to the HP, rather lean conditions as NicePony pointed out is what has been the cause of every failure I am aware of on the 4.0. There are lots of stock engines out there running over 300 RWHP and >400 RWHP. I ran around 300 RWHP for over 100,000 miles on mine - and that included weekend drag racing the car and daily driving it year round.
Old 1/12/13, 05:15 PM
  #63
EuroGirl's Avatar
I said 300-350 was about as much as stock parts can take. I never said they would immediately blow up on you. Having one with 400rwhp is pushing it on the 4.0 when you only have power adds without building the engine. To say that the 4.0 can take more abuse than a bigger better engine that's in the Gt is just silly. Also I have owned a 4.0 and would have gone with a Xcharger but decided not too. Running around with 300rwhp is fine which I have said. It's when you get into 400-450 that it starts to get questionable on how long the engine will last. Also I'm not talking about the engine block. That should be fine it's the other parts that will most likely have problems down the road. Not to mention other thins like the driveline and other parts not just the engine. In stock form there is just no way the 4.0 can handle 400+ and not have issues down the road. Also a lot of other people on other forums also have come to a consensus about this as well. Most the 4.0 can handle 100% perfectly fine is 300-350rwhp. Never said it could handle that
Old 1/13/13, 10:43 AM
  #64
Nice Pony's Avatar
Neither the 4.0 V6 or the 4.6 V8 are designed specifically to make more power than what they come with from the factory. The engineers build in a margin of safety so the engine can at least last 100,000 miles or so to cover the warranty and this has to happen regardless of how the owner drives the car. Even so even stock engines fail occasionally.
My point is if you are genuinely worried you may brake your engine or drive train by altering it for more power than it has stock then you simply should not change it from its stock configuration.
On the other hand if you are willing to take the risk, and there are certainly risks, than you assume the responsibility for your decision and the research into what is known to be reasonably reliable without much worry of braking the engine. As pointed out by both JimC and myself, done right the 4.0 can go well over 150,000 - 200,000 mile running a supercharger with plenty of trips to the track and daily hard driving.
You chose to go the V8 route but there are plenty of us out there that don't see the need or even have the desire to run a V8 when the V6 will perfectly suit our needs without having the same old V8 setup as every GT on the road. For some of us it adds to the enjoyment running a V6 that will easily beat a stock GT and most bolt on V8s as well. It is priceless to see these guys scratch there chins at the track after loosing to a V6. Don't bother trying to convert us to the V8 GT hype. That is why we are posting in the V6 section. If people have GT envy they simply need to sell their V6 and get a GT or they will never be happy. I personally could give a rip if a guy is driving a 4, 6 or 8 cylinder Mustang. They are all still Mustangs. I would never try to talk someone into choosing a specific type of Mustang, unlike a lot of GT guys that think there isn't another choice and hate on V6s, that is totally up to their own personal preference.
My V6 was tuned to around 330 RWH and I literally did a WOT acceleration to red line in 4th gear onto the freeway every day for over four years not to mention open track sessions some of which were up to 45 minute long. Like JimC stated virtually every engine failure to date can be traced to fuel delivery/tune issues which leaned the engine causing detonation and braking a piston. The exceptions were a few pushing turbos to the limit pushing over 500WRHP and windowing the block because of a failed stock rod. In my case I went into a large 360° corner during an autocross without enough fuel in the tank to prevent the pump from drawing air and instantly leaning out the engine resulting in server detonation which broke a piston. This was totally my own fault and not a fault of the engine or supercharger. And this was at 150,000 miles on the engine 120,000 miles of which was ran with the supercharger installed.
Now I'm running forged pistons and rods with stage two heads and over 14lbs of boost without issue. According to all calculations it should be in the 400+RWHP range and by the feel of it and driving my sons 2009 GT 4.6 V8 Edlebrock supercharged with 5PSI, which is also in the 400+RWHP range, the cars are pretty much the same. But also take into consideration I am not the least bit worried about blowing up the engine. If it happens it happens. It isn't the end of the world for me!
Old 1/13/13, 10:46 AM
  #65
EuroGirl's Avatar
Neither the 4.0 V6 or the 4.6 V8 are designed specifically to make more power than what they come with from the factory. They engineers build in a margin of safety so the engine can at least last 100,000 miles or so to cover the warranty and this has to happen regardless of how the owner drives the car. Even so even stock engines fail occasionally.
On the other hand if you are willing to take the risk, and there are certainly risks, than you assume the responsibility for your decision and the research to what is known to be reasonably reliable without much worry of braking the engine. As pointed out by both JimC and myself, done right the 4.0 can go well over 150,000 - 200,000 mile running a supercharger with plenty of trips to the track and daily hard driving.
Mine V6 was tuned to around 330 RWH and I literally did a WOT acceleration onto the freeway every day for over four years not to mention open track session some of which were up to 45 minute long. Like JimC stated virtually every engine failure to date can be traced to fuel delivery issues which lean ed the engine causing detonation and braking a piston. The exceptions were a few pushing turbos to the limit pushing over 500WRHP and windowing the block because of a failed stock rod. I my case I went into a large 360° corner during an autocross without enough fuel in the tank to prevent the pump from drawing air and instantly leaning out the engine resulting in server detonation which broke a piston. This was totally my own fault and not a fault of the engine or supercharger. And this was at 150,000 miles on the engine 120,000 miles of which was ran with the supercharger installed.
Now I'm running forged pistons and rods with stage two heads and over 14lbs of boost without issue. According to all calculations it should be in the 400+RWHP range and by the feel of it and driving my sons 2009 GT 4.6 Edlebrock supercharged V8 with 5PSI, which is also in the 400+RWHP range, the cars are pretty much the same. But also take into consideration I am not the least bit worried about blowing up the engine. If it happens it happens. It isn't the end of the world!
Ill let you 4.0 people believe what you want but sooner or later if your running 400+ rwhp with stock internals something will break just a mater of time.
Old 1/13/13, 10:55 AM
  #66
atrav83's Avatar
He just said he had a built engine......
Old 1/13/13, 11:01 AM
  #67
EuroGirl's Avatar
I'm talking about a 4.0 with a stock engine! Why doesn't anyone read my posts right?! Also a stock engine can take around 300-350. 400+ not going to happen for very long without forged internals.
Old 1/13/13, 11:09 AM
  #68
atrav83's Avatar
You didn't read the post before right, that's why I point that out. The guy you quoted has a built engine not stock
Old 1/13/13, 11:12 AM
  #69
EuroGirl's Avatar
Ah I see, why hasn't anyone corrected me before this? Could have avoided the whole arguement.
Old 1/13/13, 11:30 AM
  #70
atrav83's Avatar
Well the first post you argued with was correct. Im just saying the last guy you quoted. But on the argument part, there's people who run theirs cars daily and many more who prove you wrong so....argue away lol
Old 1/13/13, 05:51 PM
  #71
legacy Tms Member
JimC's Avatar
Actually NicePony only built the engine recently. Up until he went lean in a race he was on the stock engine, stock internals. Again, it was a lean condition that caused his failure. We both put well over 100,000 miles on the 4.0 with 300 RWHP, NicePony does road course racing and I did drag racing - on the stock internals and stock engine. And EuroGirl you did say that I was just lucky to not have a failure with my set up, which was not anywhere near 400 RWHP.
The failures were the result of lean conditions (and in one I know of trying to push 25 lbs of boost and he was estimated at that point to be almost 600 RWHP, estimate only because he broke on the dyno).
I know of at least one turbo 4.0 that is running on the stock internals, no forging, pushing 450 to the rear wheels with no issues.
Old 1/13/13, 07:45 PM
  #72
EuroGirl's Avatar
Ok well I know my GT has a better motor so by your logic I should be able to run twice my stock output which is 520rwhp. Also I did not say you were lucky to have 300-350. I said u were lucky to run 400+ with stick internals.
Old 1/13/13, 08:32 PM
  #73
atrav83's Avatar
Are you gonna turn this into a who has a bigger engine? Many people put facts in front of you, just accept it lol
Old 1/13/13, 08:35 PM
  #74
EuroGirl's Avatar
There were no facts o support the whole 400+ rwhp on a 4.0 it's just not going to last long unless it's built. A stick 4.0 isn't going to handle that much power for very long and to say it can handle more power stock than a 4.6 is stupid also many other forms support what I've said.
Old 1/13/13, 08:38 PM
  #75
atrav83's Avatar
Your the only one comparing the 4.0 to the 4.6. But you obviously are set in your opinion so that's ok too
Old 1/13/13, 08:46 PM
  #76
EuroGirl's Avatar
I'm not going to argue with you go turbo your 4.0 to 400+ rwhp and don't come crying when it breaks on you. Don't mind what I say even though countless people from countless forums say the same thing.
Old 1/13/13, 08:58 PM
  #77
stupidgenius36's Avatar
She's just a troll. Just put her on your ignore list, and you never even have to see her posts.
Old 1/13/13, 08:59 PM
  #78
EuroGirl's Avatar
No I'm not dont blame me because people from other forums support what I say I don't get this from no where but fine if this is how the forum is going to be I'm leaving. Also stupidgenius your a *******
Old 1/13/13, 09:08 PM
  #79
The01Cav's Avatar
Pics of said Eurogirl will completely shut me up lol
Old 1/14/13, 08:00 PM
  #80
Nice Pony's Avatar
Well EuroGirl has her facts wrong not only on the 4.0 but also on the max horsepower a stock 4.6 can be generally safely be taken to which is at least 100+ more horse power then she states. Hell, Ford racing sells a bolt on supercharger kit that brings it to 550 horsepower with no internal modifications to the engine. I'm convinced she has no real life experience with building or modifying engines so her comments just need to be taken with a grain of salt.
Quick Reply: turbo or supercharger?
