Boss 302 Steering Wheel Into '05 GT!
Old 4/24/12, 09:08 PM
  #81
Taxman72's Avatar
Originally Posted by Zaksgt
Looks good! But not a boss wheel
Yeah I didn't notice the difference. It's the regular GT wheel I guess. It wasn't advertised as a Boss, it just looked the same to me.
Old 5/8/12, 09:49 AM
  #82
sonic245's Avatar
I still have not been able to find the second place to plug in the WPT440 wiring harness. I found the one at the bottom of the clock spring, but can't find any at the left side. Anyone set this up and can upload a photo or some kind of drawing?
At the left side of the clockspring, there's another socket for a WPT-440. Extend a cable from the same pin that you plugged in above to the Steering Wheel Interface (White at SWI-JACK) and follow instructions for your interface (for 2012 Mustang: Cut appropriate wires, solder in a 100ohm resistor and program)
^This is what I can't find.^
Any help is greatly appreciated, and apparently I need plenty of help!
Old 5/12/12, 11:32 AM
  #83
MethodMas's Avatar
Connectors
Are there any part numbers printed on te '05 and '12 steering wheel connectors? I'd like to try and find the connector itself (instead of the Ford WPT-440) and the mating connector. I'm hoping they are just molex connectors. I'd like to build an adapter from the 12 pin connector to (2) 6 pin connectors instead of cutting and splicing all of the wires. If you can post any part numbers or clear photos of these connectors, I'd really appreciate it.
Old 6/9/12, 06:01 AM
  #84
Redfireshaker06's Avatar
Hi guys, I am still not understanding the audio controls installation. If you have 2 of the 440 harnesses and the PAC adapter. Where do you wire up the other 5 wires that are left after the cruise install? (I know theres 6, but the green goes to ground). And where do I hook up the white wire from the PAC?
Please help, I was hoping to attempt this today. My father bought me one of the GT500 wheels. WOO HOO lol
Old 6/12/12, 04:09 PM
  #85
deathstroke's Avatar
I just got my BOSS 302 steering wheel today. I don't want to mess with it yet as my car is in the body shop. One question I have though is the 3 plastic covers on my stock '06 wheel were removable. Are the covers on this wheel removable?
Old 2/21/13, 03:29 PM
  #86
kevDon92's Avatar
Bump! Just installed mine and am trying to figure out how the second 440 harness connects as the instruction aren't too clear to me
Old 2/22/13, 12:10 PM
  #87
Scruffy281's Avatar
To sum up: To get the steering wheel to work with a PAC SWI Jack, you need to ground the Green cable in the steering wheel and connect the purple cable in the steering wheel to a pin on a WPT-440, then plug it into the bottom socket of the clockspring.
Old 2/22/13, 01:17 PM
  #88
Scruffy281's Avatar
http://www.moddedmustangs.com/forums...-controls.html
Old 2/23/13, 07:49 PM
  #89
kevDon92's Avatar
Just saw the MM thread the other day. Thanks.
Old 4/9/13, 06:21 PM
  #90
njmustang's Avatar
Hi
Hi Thanks for the write up. Here is another look !
I did some research and i found how to get Cruise Control to work - i haven't got the time to do this but when i do i will and ill let u guys know .
The Quote under is taking from another forum i don't take credit for it please keep that in mind
Cruise Control Splicing:
Old Connector >>> New Harness:
white >>> gray
blue >>> brown
red >>> red (pwr)
green >>> black (gnd)
The resistance between the new harness gray and brown wires is as follows as each button is pushed:
OFF = 0 ohms
ON = 1500 ohms
RESUME = 1000 ohms
SET (-) = 300 ohms
SET (+) = 600 ohms
Music Controls: (I don't have these working yet; however, this is the resistance between the new harness green and purple wires as each button is pushed)
Music Icon = 510 ohms
VOL (-) = 50 ohms
VOL (+) = 120 ohms
|<< = 335 ohms
>>| = 210 ohms
Phone Controls: (I don't have these working yet; however, this is the resistance between the new harness yellow and blue wires as each button is pushed)
Speaker Icon = 50 ohms
OK = 335 ohms
Phone Icon = 510 ohms
Attached Thumbnails Boss 302 Steering Wheel Into '05 GT!-59772_10151523469804526_193326036_n.jpg
Old 9/7/13, 05:04 PM
  #91
Scruffy281's Avatar
Any updates on the other controls?
Old 11/20/13, 04:05 PM
  #92
akdoggie's Avatar
Question to the guys who have done this to your 05-09 cars and used the GT or Boss style later steering wheels.
Where did you, or better yet, how did you use the right side wpt440 to hook to the steering controls? What I mean is, how did you run the wires from below the clockspring to the s/w controls?
Running the left side wpt440 is not a big deal. Wire 1 goes to J1 #18, wire 2 goes to J1#19 (radio + & - buttons), wire 3 goes to either J3 #4, depending on which SWC you have (SWC 1 shown, SWC 2 uses different slots), wire 4 goes to J3 #5 Sync goes in #5, and the 6th wire is either left blank or use for phone control. That would take care of all 6 leads from the wpt440.
I just don't want a lot of wire laying around, but I wonder just how to go about the turning aspect and the wiring. I have everything hooked up to work properly and does. Before I button up everything, I just want to make sure nothing can rub etc. So, how did you run the wires from the right side lower clock spring to the wiring in your 2012 GT or Boss steering wheels? Thanks.
Old 11/25/13, 10:22 PM
  #93
akdoggie's Avatar
Just a note for guys going to make this switch over. The WPT 440 has been replaced by Motorcraft. It's new number is WPT 1242. It comes with green wires now and 6 pieces of shrink wrap and instruction sheet in the package. The new Ford number is 3U2Z-14S411-MJB. I found a place that sells them for under $26.00 each. That beats anyone else by at least $6.00 a pop, and they send the new update number. I got them in 3 days in AK. Not bad if you ask me. I don't know if I had better say a name, but I think I can PM them back to you. I'm just trying to keep in the good graces of the mods.
Old 7/19/14, 11:36 PM
  #94
Phorty's Avatar
FINALLY got around to putting the 2012 GT steering wheel on my 06 GT today. Wasn't attempting to do audio controls, just the basic install. I love the new wheel. Cruise control works fine but I'm not getting any lights on the steering wheel buttons when the headlights are on. What could I have messed up?
Old 3/6/16, 03:34 PM
  #95
Kellyjoe's Avatar
wpt-440 is replaced by WIRE ASY - FORD (3U2Z-14S411-MJB)
Old 5/30/16, 08:56 PM
  #96
Morereps5's Avatar
Originally Posted by ov3n
It has to exist, he says he ordered it. LOL
The 2012 looks like WPT-834 (Tin) - 4U2Z-14S411-MA
Old 7/24/16, 12:51 PM
  #97
ffvamp69's Avatar
Hi I'm Fernando from Spain .....
I'm trying to understand the procedure for audio to work but my inges a little bad and the images that appear on the other forum where they explain how to do it are not very clear ...
Someone got him to do and can explain it a little simpler or clearer images ?? or refer to another place where it explained well?
Thank you very much and greetings to all from Spain !!
Old 8/5/18, 03:23 PM
  #98
area5179's Avatar
I finally installed my Boss steering wheel in my 05 GT. It looks great and the cruise control works flawlessly thanks to the wiring help from this forum. I'm not hooking it up to my Pioneer head unit as I mostly listen to my iPod and rarely listen to the radio but I left that connection intact in case someone else wants to hook it up.
mark0006
9/4/15 10:41 AM
cloud9
GT350
8/18/15 01:34 PM
tdf017
8/5/15 10:13 AM
Quick Reply: Boss 302 Steering Wheel Into '05 GT!
