replacing my shaker 500
Old 5/16/11, 06:26 PM
sanes05's Avatar
I recently purchased the Pioneer AVH-3200DVD unit to replace my Shaker 500 head unit. I also purchased the Metra double din dash kit and wiring harness , and also a 5V voltage regulator . Is this everything i will need to make the install go smoothly and so that everything will work correctly? I saw on a couple of threads saying that you need an antenna adapter...Is this true?
Old 5/16/11, 07:14 PM
ScrmnGT's Avatar
Just installed a Kenwood in mine this weekend and no antenna adapter needed. Easiest install I ever did. Soldered the connections and put shrink wrap on them. Works great.
Old 5/17/11, 11:03 AM
ETNOATS's Avatar
Antenna adapter is for 08 and above IIRC. I have the same unit I used to replace my shaker 1000. I can feel my subs with my legs now.
Old 5/17/11, 11:17 AM
sanes05's Avatar
Awesome. Cant wait for it to arrive. This will be my first mod to my Mustang as it is completely stock. Now just to figure out what to do next.
Old 6/2/11, 12:43 PM
sanes05's Avatar
Okay. I got the unit installed. Everything looks great and it sounds great. BUT JUST ONE PROBLEM! My right door sub isnt working??? I believe I have all the wiring correct. When I disconnected the harnesses from the factory shaker, there were 3 harnesses plugged in...anyone know what that third one goes to? There was nowhere to plug it in. It just has a pink wire and a pink/white wire running to it. The Metra harness I bought only came with 2 connections. So im not sure if that third harness not being connected has anything to do with that sub not working. ANY IDEAS???
Old 6/2/11, 01:26 PM
05YellowGT's Avatar
Here's a link to Taco Bill's install , it's a different unit but the principle is the same ...
https://themustangsource.com/f692/al...w-pics-455116/
Old 6/2/11, 02:34 PM
sanes05's Avatar
Ok I think the only thing I didnt do was use the splitter to spilt the RCA cables. Im not sure if that would cause the one sub to not work or not though. Ill go buy a splitter tomorrow and check it out. And I found out that the extra harness doesnt need to be hooked up. It doesnt go to anything.
Old 6/3/11, 10:44 PM
ETNOATS's Avatar
The third connector isnt used, its bus info or something like that. Make sure the connector is tight. I had to zip tie my wires over the harness to keep them from coming loose. The 8 pin plug is for the amps, 1-4 for the doors, 5-8 for the trunk. check those wires closely.
Old 6/4/11, 02:53 AM
sanes05's Avatar
Im starting to think that maybe that sub never worked in the first place. I think Ive tried just about everything and Im tired of taking the dash apart. So I guess I just need to take the sub out and test it.
Old 6/4/11, 04:17 AM
ScrmnGT's Avatar
Did you replace door speakers? If so maybe you forgot to plug the sub back in. I unplugged mine when I took the door panels off to replace the speakers then plugged it back in. If not takes about 10 minutes to pull the door panel and check it.
Old 1/27/19, 01:10 PM
stang09's Avatar
any photos
Old 1/28/19, 05:19 AM
Paris MkVI's Avatar
Necro-post. The posts are from 2011, so don't count on an answer or any pics. The OP may not even have the car anymore.
lakersfreak
6/13/22 12:29 AM
kponypower
6/17/20 07:17 AM
10/2/15 01:00 PM
PonyMuscletang13
9/29/15 09:40 AM
Quick Reply: replacing my shaker 500
