Sponsored by:
Sponsored by:
Overly Sensitive Factory Alarm
Old 10/14/09, 11:42 AM
Gooch's Avatar
Does anyone know how to adjust the sensitivity to the factory anti theft on a 2006 GT? It has gotten to the point where I can't arm the alarm at all anymore and I have had to resort to manually pushing down the locks when I get out of my car. If there isn't an easy way to adjust the sensitivity is there a way to disable the anti theft alarm from being turned on when I lock the car with my FOB?
Old 10/14/09, 01:22 PM
Founding MOTM
Committee Member
Antigini-GT/CS's Avatar
I've had that same problem twice since i've had the car. Both times, I took the car to the dealer and let them fix it.
Old 10/14/09, 01:59 PM
GottaHaveIt's Avatar
it's kinda of a PITA but it's in the drivers book I could not get it but my 13 year old kid can Tik me off !
Old 10/14/09, 03:38 PM
classix_stang289's Avatar
lol its crazy to say but i have had the same problem with it being sensitive and i have done nothing and just dealt with it for some time without changing anything and now its much better for some reason. not as sensitive and i havent even touched a **** thing on it.
Old 10/15/09, 05:03 AM
metroplex's Avatar
Are you sure there's nothing crawling around in the interior?
Old 10/15/09, 05:06 AM
TheIrishMan's Avatar
I've got the exact opposite problem.
Had it jacked up, oil already draining out when the alarm finally went off.
Old 10/15/09, 08:40 AM
It's funny how they behave , now having a vert , with top down and armed by Fob if you move the car the anti tow goes off and the interior only seems to go if you open the door , so I gather the motion becomes deactivated , but it I put the top up then leave a window down & a leaf blows in all hell breaks loose so to speak.
Anyone ever travelling on a ship or Ferry should do this, when you exit the car DO NOT use fob but just the key in drivers door to lock it / this wasy it disables the motion/anti-tow alarm and leaves the motion sensor or interior good , so if someone goes it it will go off.
I have seen people use thier fob have it go off and even two vert tops get slashed for the anoying horn going off, some even get keed up. So lock on a Ferry by KEY.
Old 10/15/09, 07:11 PM
theedge67's Avatar
Lock the driver door by key in the lock cylinder. It will arm the doors/trunk/hood sensors, but not the motion detectors. Or you could try and reset everything by disconnecting the battery for a few minutes. That may or may not help. I have found that as long as I keep my windows up, everything is fine. If I leave a window down though, even a person walking near the car can set it off.
2/10/17 07:12 PM
PonyMuscletang13
9/26/15 02:33 PM
9/23/15 03:21 PM
Fred_Garvin
9/17/15 04:10 PM
9/10/15 12:44 PM
Quick Reply: Overly Sensitive Factory Alarm
