Key FOB not working
Key FOB not working
Even though I usually change my own oil, I took it to a mechanic because I was low on time (yeah, I know, lesson learned). Anyway, now nothing on the key FOB will work. Not only that, the door locks won't work when putting the key in the door (I can lock/unlock only the driver side).
Interestingly, they door locks work fine when using the inside switch. And everything else seems to be OK (drove home fine, radio works, etc.)
Any ideas as to what happened or how to fix it?
(and no, my door lock fluid isn't low )
Thanks.
Thanks.
Received 2,542 Likes
Check the Battery in the Transmitter??
Might Also Try Disconnecting the Car Battery For About 10 min and Then Check it out.
Kc
Kc
Now you can read the manual on how to reprogram the fobs.
Hey Rampart, you may just have to re-program the remotes. Its REAL simple. Here's what you do:
1. Get in car, and shut doors.
2. Have BOTH remotes with you.
3. Put key in ingition
4. Cycle key from OFF position to ON position (but don't start the car, just ON position) 8 times within 10 seconds, with the 8th time ending with the key in the ON position
5. When you do this correctly, the locks will cycle (lock and unlock). This signifies your in "program mode"
6. Once they cycle, push the lock button on Remote #1, then lock button on Remote #2 (and do the same for any more subsequent remotes)
7. Turn key back to OFF position (locks will cycle one last time, to signify leaving "program mode"
8. DONE! Try each remote. They should work like champs!.
Hope this helps bud.
silverjoy (7/12/18)
If all you have is 1 key and 1 remote you should still be able to re-program.
For some reason, I thought I had to have two. Can you get a new key FOB and program it the same way?
Thanks again. It was so frustrating without the FOB
"6. Once they cycle, push the lock button on Remote #1, then lock button on Remote #2 (and do the same for any more subsequent remotes)"
9/10/15 12:44 PM
9/8/15 10:45 AM
