Sponsored by:
Sponsored by:
Power window problems need help
Old 3/13/08, 03:45 PM
Antrax's Avatar
I'm having problems with my 2005 GT. The automatic power window function isn't working right. I can use the automatic function (one touch to open and close the window) to open the window but not to close it. I can close it manually (keeping the switch pressed) but the window didn't work properly when I open and close the door. This is only happening on the driver side, the passenger side works OK. I tried to find the problem with the wiring diagram but no luck what so ever.
If someone have any idea that could help me, please, please, let me know.
Old 3/13/08, 04:25 PM
DoctorQ's Avatar
There is a power window re-initialization procedure in the owners manual (takes all of 15 seconds to perform)... or follow this one posted earlier: http://forums.bradbarnett.net/showpo...1&postcount=10
hope that solves your issue.
Old 3/13/08, 08:24 PM
Mach's Avatar
Had the exact same problem...just recalibrate as described in the manual...all will be good!
Old 3/13/08, 10:13 PM
Antrax's Avatar
Thanks, the recalibration worked nicely. The power window is now working perfectly.
Old 3/14/08, 09:15 AM
Retired Tms Staff
adrenalin's Avatar
You will find that the problem will come back every now and then, just keep doing the same procedure. My passenger window does that about every 2 weeks. Basically this is the reason Ford stopped including the feature after the 2005 model.
Old 3/14/08, 12:03 PM
highvolts's Avatar
I have a 2007 with the auto up and down.. What didn't they include?
Old 3/14/08, 04:46 PM
theedge67's Avatar
Don't you love when you search so hard for an answer to a problem....only to find the answer in the owners manual? Everyone should read their owners manual cover to cover. Everyone.
Old 3/15/08, 05:57 AM
MUSTANGLOVER73's Avatar
my 06 has it as well. has malfunctioned once. the rpair worked flawlessly
Old 3/15/08, 06:05 AM
bee bop's Avatar
I think what Adrenalin is refering to is the Global Window Feature. This is where you could raise or lower your windows using the Key or Fob. The early 05s had this feature, but Ford had issues with it malfunctioning and lowering the windows by itself. The stopped enabling it in Jan 05 and completely removeed the feature by April. Some have had luck getting it working again if their car was built before April, but if it was built after that you don't have some of the wiring or hardware required.
Old 3/15/08, 08:11 AM
Mach's Avatar
IMO there should be two or the manual should be divided into two parts... One for those that have never owned a Ford Product or perhaps never owned a vehicle, and those that HAVE read an owners manual at some point before. I believe the important thing is to have it in the vehichle with you and should a problem arise, be able to refer to it. When the answer is lost in the text, then go to our forum and post...this method has worked flawless for me...
Old 3/15/08, 08:18 AM
highvolts's Avatar
got ya!
Old 3/15/08, 01:45 PM
n8rfastback's Avatar
i have the global window feature on mine, and i love it!
i can have the windows down before i get to the car when its hot out... yea!!!
Uofmrampage
8/2/22 02:55 PM
iliveonnitro
10/7/21 06:31 PM
Mpaps
10/11/17 08:06 PM
CiniZter
25
4/28/16 05:41 PM
CoyotePremium13
9/23/15 06:45 PM
Quick Reply: Power window problems need help
